2013 QX56 location of factory harness for electric brakes
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
hummer3t
Car: 2013 Infiniti QX56
I've looked underneath the dash, to the left of the steering column, in the vicinity of the emergency brake pedal and even went so far as to remove the trim panel to the left of the emergency brake and cannot locate the harness. The vehicle is equipped with Tow Haul so I'm assuming it should be pre-wired with the harness. Anyone have any suggestions?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It will be taped tight to the side of a Main Harness leg, not dangling loose. On Armadas and QX56's they're usually way up there.
hummer3t
That's what I read, but couldn't locate it, I'll give it another look, up higher as you mention, thanks.
hummer3t
I just found a thread from June 2018 which actually had a picture of the harness taped to the main leg as you mention, looks like its taped to the reverse side of the harness which might explain why I couldn't locate it initially. Apparently I was looking on the wrong side, found it!
Return to “Armada Forum / QX56 Forum / QX80 Forum”
