Hot fluid. It's possible they overfilled it when they did the service. Overfilling causes foam which in turn causes "hot spots" on the belt and can quickly overheat the trans. The "behavior" is software, the TCM shuts the transmission down when the fluid temp gets too high. Back in the early days of CVT's, Nissan went out of their way to "black box" it as much as possible to both technicians and the public. There were no reman kits, little info, no warning lamps, and for the first few years a "lifetime fluid" claim. It was all baloney, of course, but Nissan was invested in it so changes took a looooong time.raven69david wrote: ↑Mon Mar 02, 2026 10:59 pmLooks like it just started happening not too long ago and the van is a 1 owner. My initial assumption was that the fluid had never been changed but the CARFAX shows it was changed on 5/18/24. I’m trying to source a reman’d unit and there are many used ones in my area.
What causes this issue/behavior to begin with?
VStar650CL wrote: ↑Tue Mar 03, 2026 7:03 amHot fluid. It's possible they overfilled it when they did the service. Overfilling causes foam which in turn causes "hot spots" on the belt and can quickly overheat the trans. The "behavior" is software, the TCM shuts the transmission down when the fluid temp gets too high. Back in the early days of CVT's, Nissan went out of their way to "black box" it as much as possible to both technicians and the public. There were no reman kits, little info, no warning lamps, and for the first few years a "lifetime fluid" claim. It was all baloney, of course, but Nissan was invested in it so changes took a looooong time.raven69david wrote: ↑Mon Mar 02, 2026 10:59 pmLooks like it just started happening not too long ago and the van is a 1 owner. My initial assumption was that the fluid had never been changed but the CARFAX shows it was changed on 5/18/24. I’m trying to source a reman’d unit and there are many used ones in my area.
Anyway, most shop scanners (even high end ones) can't read CVT-A/CVT-B, so you might want to get a 'Droid emulator or befriend somebody with a 'Droid to see how bad things are. If it really has only heated up a few times, do a couple of consecutive fluid swaps with about 1K in between, to void most of the old fluid and assure that the level is right. Equally important, put a cooler on it immediately. Because of the way the engine box and radiator are arranged, the Quest heat exchangers are particularly inefficient and a cooler does them a world of good.
I definitely plan on keeping it. The van is a 1 owner with impeccable records from the Nissan dealer. The only thing they overlooked was the transmission, the Achilles heel of this van.VStar650CL wrote: ↑Tue Mar 03, 2026 8:55 amSure, but anytime you get overheating severe enough to trigger self-protection, there's a very good chance the belt and Valve Body are both being damaged. So the real question is, did you buy the vehicle to use, or to resell? If you're turning it over, then simply making sure the fluid level is right and adding a cooler may alleviate the self-protection. It may start slipping someplace down the road, but that's caveat emptor. If you're keeping it then the answer is different, complete due diligence is called for. I'm sure you don't want you or your family stranded because some already-damaged hardware eventually broke. So the first thing you need to do is upload CVT-A/CVT-B to see how bad the problem is. If there have been more than 4 or 5 episodes, I pretty much guarantee you there have been multiple instances of judder and the belt is damaged. Fresh fluid and coolers won't fix that. If you want to inspect the belt it's doable with a borescope, this bulletin is for the '10D trannies but the '09B's use a similar belt which will exhibit damage in the same way:
https://static.nhtsa.gov/odi/tsbs/2019/ ... 8-0001.pdf
I just purchased a Hayden cooler and bought a cheap android phone and a Veepeak Bluetooth dongle so I can download CVTz50 and use it to scan the trans. As long as the van drives without any issues for 15-20 minutes in this Texas heat, I’d be comfortable completing the purchase and then adding the cooler as soon as I get home. Thoughts?VStar650CL wrote: ↑Tue Mar 03, 2026 2:05 pmThat pic isn't a cooler, it's a warmer, and your Quest already has one (albeit the flat-square type and not that one). We call those "beehives" because they resemble a beekeeper's box. The arrangement is kind of bassackwards because the beehive and the heat exchanger (embedded in the radiator) work at cross purposes, the beehive heats the fluid and then the exchanger has to cool it off again.
Would it have made more sense to embed a fluid thermostat into the beehive? Sure.
Did they save $1.00 by not doing that? Sure.
Did they blow up a lot of transmissions because of it (including under warranty)? Positively!
The Quest has a particular problem because the outlet tank temperatures in the radiator tend to run hotter than most other models. That leaves the heat exchanger working with one arm figuratively tied behind its back whenever the engine is working hard. Adding a radiating cooler like a Hayden 512 or 697 in series with the heat exchanger improves things, giving the system extra cooling power when the outlet tank temp rises. When I talk about adding a cooler, that's what I'm talking about.
I can’t thank you enough for your help. Your encouragement and insight really helped me in solidifying my decision. Let’s hope it’s worth it.VStar650CL wrote: ↑Tue Mar 03, 2026 3:33 pmSure. It sounds like the van is worth fixing up even if the transmission turns out to be a loss, but it will be a lot easier to figure out the latter once you can pick the TCM's brain. Post back what you find.
Is there a diagram that shows the inlet/outlet locations of the vehicle so I can make sure I route the correct lines to/from the external cooler? I couldn’t find them in the FSM.VStar650CL wrote: ↑Tue Mar 03, 2026 3:33 pmSure. It sounds like the van is worth fixing up even if the transmission turns out to be a loss, but it will be a lot easier to figure out the latter once you can pick the TCM's brain. Post back what you find.
Thank you. My plan was to run the cooler inline with the rest of the system. I was going to disconnect the return line on the radiator, run that to the cooler and then connect the return line, already attached to the beehive, to the outlet of the cooler.VStar650CL wrote: ↑Fri Mar 06, 2026 10:23 amOn beehives, the larger lines are coolant. On that style of square one, the port pointing down is the pressure port, the one pointing up is return. Generally the most convenient routing for a cooler is to send the pressure port to the new cooler, the new cooler outlet to the heat exchanger inlet, and leave the return line from the heat exchanger outlet alone. On the '09B Quests there's a coupler in the pressure line in between the hive and radiator, that's usually a good spot to reconcile hose sizes if the new cooler hoses are 3/8" (the OE hoses are 8mm ~ 5/16").
I plan to run the cooler in series, as the diagram in the box suggests.VStar650CL wrote: ↑Fri Mar 06, 2026 11:01 amPS - And the pressure line (lower on the radiator) is much easier to plumb to the front than the return line.
So if I mount the cooler like this, the transmission oil connection coming out of the lower radiator should go to the bottom connection of the new cooler. The oil should then flow up the cooler and out the top connection which will then run back to the transmission. Correct?VStar650CL wrote: ↑Tue Mar 10, 2026 2:20 pmSeries is the right way to go, but on almost all Nissans it's physically much easier to plumb the cooler between the pressure port and the radiator than between the return and the radiator. The reason is, on CVT's, Nissan sends the pressure port to the bottom of a crossflow radiator. The return flow comes out the top, which lets buoyancy help chase bubbles out of the heat exchanger. Putting the add-on cooler on the return side results in much longer hoses, because you need to loop underneath the radiator from the top of the radiator tank instead of the bottom. Very messy and there's no good reason for it, series is series regardless of which device is first in line. The total BTU's dumped by the installation will be the same either way.
It was aVStar650CL wrote: ↑Tue Mar 10, 2026 5:28 pmThe hose going into the lower radiator is pressure, it comes from the transmission and not to it. Disconnect it from the radiator and connect it to the bottom of your new cooler. Then route the top of your new cooler back to the bottom of the radiator. I mentioned earlier that you'll need to reconcile the tube sizes, your OE lines will be 5/16" and the Hayden 678 uses 3/8". You'll need a pair of barbed reducers like this (brass or stainless are both okay):
I also mentioned earlier that there should already be a 5/16 x 5/16 union in the middle of the pressure line. That's usually a good spot to split and reconcile the lines.
Calibration ID: 0000 0000 0030 0018 00E5 006D (04 89VStar650CL wrote: ↑Wed Mar 11, 2026 8:33 pmPretty crappy resolution on those pics, but I think I'm seeing 10 CVT-B's, a P0746, and a P0868? If so, you need to do a belt inspection to find out if there's anything to save. P0746 and P0868 aren't "hard" codes, they both indicate that the TCM commanded one pressure and ratio and got a different result -- i.e., the belt was slipping. With 10 overheats you're kind of on the border, if the belt checks okay then you might save it with a complete fluid change and a new Valve Body. If the belt is damaged then she's done. Break out your borescope.
Thanks to you, I saved myself a lot of grief but I did learn what to do when it comes to buying a Quest. I can’t thank you enough for all the help and wisdom you contributed to my journey with this particular Quest. You’re an amazing person and such an asset to this community.VStar650CL wrote: ↑Thu Mar 12, 2026 5:12 amStill sounds like a slippy belt. The P1701 is likely a battery issue, but the other two are typical of a belt which is dead or dying. If the interior is screwed too, I'd give that a hard pass. Now at least you have a tool to check the next candidate.
Another “winner”
Exactly. It’s saved me twice now. It’s worth the $5.VStar650CL wrote: ↑Sat Mar 14, 2026 1:03 pmYowch, 3 major overheats and a whole lot of slip-slide. That one's a big mess.
Welp, that's exactly why CVTz50 is invaluable when Nissan-shopping. Case closed.
