I when ahead and took everything off and i have to tell you i was mad confuse lol... i disconnected the screen, the front plate and the Radio/AC panel off.. so what i tried to do was make the adjustment explain on this post
:post6496437.html#p6496437
I Connected it to this plug that is the only 1 with 2 rows of 16pins located on the bottom left on the back of the unit which is the one under the CD player (Not sure if thats the one ) .. i thought it was it bcuz when i turn on the car with the Ebrake on the screen for the video showed and when i disconnected that plug the screen would go back to normal setting...BUT the color don't match on that plug!! i tried doing what the post said but nothing.. I looked at this AV manual i found and i couldn't find the damn plug and/or cables (VSS & E-Brakes)!! i ended up cutting the wrong one and just got frustrated and put everything back....
please help me out here guys..
: http://www.nicoclub.com/FSM/Pathfinder/ ... der/AV.pdf
i used this manual and i can not find the right setting or page i should be looking at let alone the plug.. please help! i have the SV model 2013 Pathfinder (Bluetooth/back up camara/sensors/RCA input) im trying to make it work where i can connect w/e i want thru the RCA input and watch it while i drive.....
