2013Altima »
https://forums.nicoclub.com/2013altima-u278009.html
Thu Oct 12, 2017 4:46 pm
2013 Nissan Altima 2.5 s (4 cylinder). The car has 105k miles. The car started to run like crap when you turn it on. Sometimes it turns on and then turns right back off. Other times it runs but stutters, bucks, and the rpm’s flutter. If the rpm’s are between 800 and 1,600 rpm’s the rpm’s will just keep bouncing around and flutter. If you put the car in drive or reverse it will buck and want to launch forward sometimes. If you start to drive it above 5mph or above 1,600 rpm’s it’s as smooth as can be. You can floor it all the way out and the car has no issues until you come to a 5mph or so or a dead stop and then it acts up again. It displays a P0014 code. I looked it up today and thought it might be the camshaft sensor. There’s two but I only bought one but swapped it around with the two that were there. It still has the same problem. I’m thinking I should replace the crankshaft sensor as well but at this point I found 2 guys online who said it could be the timing chain jumped. Which doesn’t make sense to me because it runs so good above 5mph or above 1,600 rpm’s. Any ideas?
