I have a 2013 Infiniti M37 whose XM radio suddenly started to have issues. I can start the car and it works fine for about 3-8 minutes, then it starts to break up and then says No Signal. I have searched forums and other resources but no real conclusion on what the issue is. With it working fine for a few minutes (whether standing still or moving), it almost seems to be something like once it heats up it cuts out....I just don't know. Infiniti says it will be around $200 to diagnose, $750 to fix if it is a radio issue, and around $3500 if replacement is needed. Just wondering if anyone has run across this issue and could lend some insight. Seems replacing the antenna might be a feasible troubleshooting step (and probably the least cost), but I would think if it was an antenna issue it would not work at all (or be sporadic all the time).
I welcome all insight, Thanks!
