2013 M37 Sport blower motor question
13M37SAZ
Car: 2013 Infiniti M37 Sport
2013 M37 Sport. when AC is on, I do hear a blower motor spinning, is it normal? I assume it is not. Usually you do not hear it. How difficult is it to replace?
Many many years ago I had a 1991 M30; it is nice to be back to the M-Series again.
Thanks in advance for the suggestions and thoughts. If any members are in the Phoenix area I would love to connect.
Reason: Revise Title
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It's behind the glovebox. Same spot as an Altima, nothing besides the cover underneath the glovebox needs to be removed. Then it's three screws (should be phillips heads if it's the same as most Nissans). Chances are something is in the cage. You probably don't need a blower, but you probably do need a new cabin filter after cleaning the cavities. It's in more or less the same spot, but I think you need to remove the glovebox.
Ilya
Yep, glovebox needs to come out for the cabin filter and to reach that area. I did a HowTo on it and it can be found in this forum.
