2013 Frontier No start after Cam sensor replacement
Serf27
Car: 2009 g37
I have a 2013 frontier SV
It was running rough and throwing a code or a camshaft sensor. I cannot remember if it was Bank 1 or 2.
I replaced bank 2 sensor and when I did, I found out the pigtail was missing and the previous owner just
Attached the wires to the sensor with small clips and I didn’t realize that till I pulled the wires out of the sensor and didnt see where exactly each wire went.
I cut a pigtail off an 03-06 g35 coupe.
The coupe pigtail had different colored wires than the frontier though.
Coupe had
Red
Yellow
Black
Frontier has
Red/pinkish
Yellow
Brown
I hooked up the wires like this
Red-Red
Yellow-Yellow
Brown-Black.
Now the truck doesn’t do anything when I turn the key.
I will say, when I pulled the wires off the sensor the first time, all 3 wires were loose and touched each other and blue a fuse. I have since replaced that fuse, but could it have done more damage?
Not sure if the camshaft wiring is wrong or if something else is the issue
Fuel pump is working and the starter will spin if signal and power are jumped together.
Sorry for the long post. Any ideas?
Thanks in advance.
