2013 EX37 side cargo nets
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
markocca
Car: 2013 Infiniti EX
I am looking for side nets to install in the cargo area of the 2013 EX37. Infinity does not offer any for the EX, so I’m hoping someone else found something that worked well. I just sold a 2010 Subaru Forester, and I purchased a set of side cargo nets (one for each side) from Subaru and each one had a mesh pocket you could store thing in, and you could also place items in between the side cargo net and the inside of the vehicle. They were awesome because I could store items on each side of the cargo area without them shifting around. I would like the same feature for my EX. I’m not sure if the Subaru nets would be the perfect fit for the EX37, or if someone else has found an ideal solution which I could copy. Have you found the ideal side cargo net solution?
EXceptional
Car: 2008 Aspen Pearl EX35 Freakin Loaded!
This might be an alternative, if you can find them. Some sites are showing it as discontinued.
http://infiniti.niello.com/accessories. ... tegory=209
Using the above item requires the Floor Mat, for it has two holes cut into it, to lock the position of the Cargo Organizer.
Good Luck...
XIS
Car: 08 Infiniti EX35 RWD
17 Infiniti QX30 Sport
BMW and Mini have nets that go by your feet.... Check eBay
EXceptional
I guess he means ones like these...
http://www.ebay.com/itm/2007-2012-MINI- ... 6e&vxp=mtr
XIS
those are similar but they go in the trunk, I can't cut and paste on my tablet... just search BMW footwell net
markocca
Thank you for your replies. Yes, that ebay link is what I'm looking for. I would like one rectangular net for each side of the cargo area. The ones for the mini look a little small. the ones I had in the back of my Subaru might be a good fit, I'll have to go to Subaru parts dept and measure to check the size. I posted in the event someone has already done the legwork and found the ideal size from some other manufacturer.
markocca
I've found my solution. I bought a set of side cargo nets for a 2010 Subaru forester and they fit almost perfectly. There is a hook on the bottom of the net which connects to the rear most loop in the cargo area. There is another hook on the bottom of the net which goes down below the rear seat area and clips onto a piece of plastic under the carpeted flap which folds with the rear seats. There are loops on the top of the nets at front and back which each require a ziptie (tiewrap) to connect to something. Using a tiewrap connect the rear net loop to a couple of the rectangular opens in what appears to be a speaker grill. Using another tiewrap connect the front loop NEAR the metal U shaped bracket that the rear seat connects to by running the tiewrap BETWEEN the carpet and plastic, and out thru the hole in the plastic for the U shaped bracket. Buy the nets and a couple small tiewraps and it will be obvious. I am very happy with this solution.
EXceptional
post some pictures please
AWGD8
Car: 2008 EX35 AWD JOURNEY
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
