Pervis12 »
https://forums.nicoclub.com/pervis12-u273930.html
Sun Nov 19, 2023 2:06 am
Hello, hope you guys are able to help me with my car issues.
This my family car 2013 Nissan Armada Platinum 4x4. Sometimes the truck will just crank but not start, after a few crank attempts, she will start up. At first I only had DTC P0340 (Cam Position Sensor Bank 1). I went a replaced the 1 cam sensor with Delphi Cam sensor SS10817. Cleared the dtc start the car allowed it to run; checked for dtc again and now I’m getting p0340 & P0335. Replaced the Crankshaft sensor with Hitachi Crank sensor CPS0005. But still getting the same 2 dtc. The truck will start and sometime just crank and no start. Also shake while driving, RPM fluctuate but never shut off. I decided to replaced the other 2 Cam sensors ( Intake Valve Timing Control Sensors; the two that sits on top of the engine front cover) Now I’m only getting p0335 no more p0340. The car still have the same symptoms; crank and no start and sometimes start, shake while driving and when I went on a test drive the truck stalled on me. I’ve checked Crank sensor and cam sensor connectors for Power, Ground and Signal. There’s also continuity in the cranks signal wire going to the ECM and the Cam signal wire as well. Do I have a bad timing?
Rogue One on Sun Nov 19, 2023 8:10 am, edited 1 time in total.
Reason: Revise Title
