2013 Altima fuel grade
RinoDNA
Car: 95' regular cab hardbody
Can someone tell me what the minimum octane requirement is for the new 2013 altima is? Specifically the 3.5 motor. Thanks.
MaximA32
Car: '98 Maxima (RIP)
'04 Maxima - Traded
'06 Mazda 6S- Traded
'15 Altima
Welcome to NICO! If you own one, it is generally in the owners manual in the recommended fluids in the maintenance section.
RinoDNA
Thanks for the welcome! No I don't currently own one, but seriously considering one. Went for a test drive with the wife and really enjoyed the way it drove (the 3.5) and how quiet the interior was, but one of the questions I forgot to ask was about the minimum octane required. Probably won't make or break the decision, just mostly curious.
xxdagam3xx
Car: 2010 altima coupe 3.5sr (CVT)
its probably regular... its an economy car
rcboy514
Car: 2013 VW Golf TDI 4dr 6-speed
2008 A/C 3.5 CVT (sold)
2004 BMW 545i V8 >:-)
1991 BMW 535i I-6
in reference to the 3.5L....the manual for the 2008's said 91 minimum, but I think they changed the 2010-2012 manual to regular 87. Try out both and see which one the car runs better on.
Warren39
Car: Nissan
RinoDNA wrote:Can someone tell me what the minimum octane requirement is for the new 2013 altima is? Specifically the 3.5 motor. Thanks.
If the factory says regular, you must stick to that. With different octane grade timing will change
Throckmorton
Car: 2007 Altima
Warren, your answer is not quite correct. The timing will not "change" if you use 89 or 91/93 octane in a car designed for 87 octane, as the '13 Altimas are.
However, if you have a Altima V6 that requires at least 91 octane, and you use 89 or 87 octane in it, once the engines spark knock sensors detect spark knock, the timing will automatically be retarded enough to prevent knock, and you will/might notice a decrease in performance.
RicerX
Car: '20 Titan Pro4X
Throckmorton wrote:
Warren39 wrote:If the factory says regular, you must stick to that. With different octane grade timing will change
Throck is correct here.
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
Just stick to the regular unleaded. There really no measurable value in using high test fuel in the 3.5 coupe. The fact that the 3.5 uses regular unleaded and still makes 270 bhp makes it an excellent engine. :biggrin:
