Hello all,
2012 Versa Sedan SV is throwing a P0300. Have checked for air/vacuum leaks. Have changed the spark plugs and gapped correctly. Have replaced the coil boots as I was having spark leak. Also have spark knock/rattle. Mechanic told me that when he hooked up his computer the car is running lean all the time. He cleaned the MAF and the Throttle Body.
Help diagnosing is appreciated.
Thank you.
