I changed the battery in my car (not the key, the 12v car battery). After changing the batter the car no longer recognizes the key. I'm guessing the issue is that I left it without any power for ~30 mins. This car has a physical key, not a fob. I'm assuming the key is chipped and the car somehow lost it's memory of the chip ID (or something similar).
I'm feeling incredibly stupid for not checking before removing the battery. I've never had this issue with a battery change before, but should have checked first. If this thing has to get towed to the dealer I'm going to be really even more mad at myself.
Q&A for likely questions
Q: Do you have another key.
A: No. This is the car for our kids. They lost the 2nd one. If the car forgot the key ID it wouldn't help.
Q: Maybe the key is bad?
A: Could be. 1 in 1,000,000 chance they key went bad exactly when I changed they battery.
Q: The key was working fine before?
A: Yes, I jump started it right before removing the battery.
Q: Why do you think the key isn't working?
A: I'm seeing the red flashing car with a key on the dash. It just flashes once, or maybe very slowly.
Q: Is the steering wheel locked?
A: No.
Q: Did you try putting it in neutral, just in case?
A: Yes.
