2012 Rogue SV roof crossbar mounting bolts
2012Rogue
Car: 2012 Rogue SV AWD
Hi everyone,
I just purchased a pair of used OEM crossbar, but it doesn't come with those 8 mounting bolts, does any body know what is the size for the bolt? And does it require a washer? :confused: :confused:
Thank you.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
If they are the same as 2011 Rogue; M6 x1.0mm. (typically with a 10mm head). Im not sure on the OEM bolt length; I made my own cross bar and bought 30mm length. Also does not hurt to have washers and locking washers too. I believe OEM bolts have washer built in.
2012Rogue
itsa300zx wrote:
Wed May 02, 2018 1:19 pm
Thank you so much, so 30mm fits well? I ordered 8 of the 20mm. Guess I need to place an new order, thank you so much for the info!
Return to “Rogue Forum”
