I'm looking at replacing the rear wiper arm on our 1st gen Rogue.
Originally I was thinking of just replacing the blade, but I took a closer look and the blade arm is cracked at the bolt hole. Cracked all the way through.
SOME HISTORY: Someone hit our Rogue in the back, so the hatch got replaced through insurance. So I'm not sure whether the cracked blade arm just happened to be attached to a used hatch that got put on our Rogue. I don't think they took the dent out of the original Hatch.
But I got 2 questions.
1) Are the cheap wiper arm+blade on Amazon (for ~$20-30) any good? Will they work well enough? Has anyone gone this route? Or is this a case where the Nissan Arm + Blade is just better?
2) Since the blade arm is cracked at the bolt hole, so do you think I'll need the battery terminal puller to get the blade arm off? I mean, the crack is completely through the bolt hole on the arm, so if need be, I could probably stick a big screwdriver in the crack and just crank the hole open more.
What is everyone's thoughts?
Any help greatly appreciated!
Take care, The Rogue
