[/quote
ras_oscar wrote: ↑Tue Feb 27, 2018 9:31 am
Only makes noise when moving. Wouldn't a serpentine belt make noise any time the engine was running?
When belts and pulleys warm up sometimes the noise goes away. Of course eventually you get the noise all the time.
ras_oscar wrote: ↑Tue Feb 27, 2018 9:33 am
Anyone have experience replacing Rogue front wheel bearings? What mileage and what were the symptoms? The only experience I have was on my 2005 Altima and that made a raucous howl.
I had to replace mine at about 35k. If you live in the salt belt plan on changing out the wheel sensors also, because of a stupid Nissan design flaw. You have to remove the sensor to get the wheel bearing assembly off and back on. Up north here wheel sensors are only removed with a drill, hammer, punch and a file.
Get a good quality wheel bearing like Timken or Moog do not buy the cheap C.R.A.P. or you’ll be doing it again in 5k miles or so.
A bad wheel bearing usually presents itself at first with a drone that goes away if you turn the steering wheel to the left or right. As it gets worse, it gets louder and the drone doesn’t go away. If you neglect it and it gets really bad the wheel will eventually fall off.
