2012 rogue coolant
ras_oscar
Car: 2012 Nissan Rogue AWD
2014 Rogue, just replaced my transmission at 125K. Also asked the dealership to replace the coolant, since it is recommended at 100K miles.
My questions:
1. Is there a coolant other than Nissan that is acceptable for use with a CVT and 100K replacement interval or am I better off purchasing coolant from Nissan?
2. Is there a CVT fluid other than Nissan that is acceptable for use with a CVT? after replacing it with only 100K mines I plan to do a routine change at 50K vs the 60K recommended in the service manual. Wondering if I could do it myself.
disallow
Car: 2010 Nissan Rogue SL AWD - 110000 km
2005 Nissan Pathfinder SE Premium 4x4 - 270000km
I'm kinda confused. You say 2012 in the title, but 2014 in the body. Though thats probably not a big deal.
To respond to your question:
1. Coolant type - Your CVT doesn't care what kind of coolant you use. I suggest you use the Nissan Blue coolant you get from the dealer. It is premixed, and is long life, with no silicates or borates. High quality stuff. When you drain the coolant out of the engine, don't use water to flush it out. The water will stay in the engine and dilute the new premix coolant you put in, which will affect its performance.
2. CVT Transmission Fluid - the general consensus here is that you should stick with Nissan NS2 CVT transmission fluid. It is expensive. But it works. There are some aftermarket options out there, but none of them are cheap enough to justify moving away from the nissan fluid, IMHO. There are videos out there on how to do this yourself. But keep in mind that the CVT is very sensitive to the fluid level, too much or too little is not good! If you aren't super confident, I would take it in.
t
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Already been covered.
Return to “Rogue Forum”
