2012 Rogue Airbag Code - 16
justin_bailey
Car: 2012 Nissan Rogue SL FWD
I finally was able to get into diagnostic mode and its one long, held flash and 6 quicker ones = 16.
I cannot for the life of me find any info on this.
Only thing I found was for a Sentra or some other in a crash sensor zone fault, or something.
If anyone has any info it would be appreciated.
Oh, I have done the airbag light reset multiple times.
TIA.
justin_bailey
I found this, just now - unsure if it's close.
https://airbagcode.com/nissan-rogue/16
justin_bailey
FWIW - Some digging showed a possible bad connection under the passenger seat - so I reconnected the yellow connector which is ALWAYS for ANY car yellow, so if you have other issues with any car, unplug and plug back in this connection.
I haven't had any airbag light flash since this - could have been loose.
Will keep an eye on it. Drove to work this morning 35 minutes, and no light. It would have went off typically in the past by now.
justin_bailey
light still flashing - off to the dealership tomorrow...................
anyone? Bueller?
Rogue One
Car: 2011 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Nissan airbag code 16 may be due to a malfunction in the crash zone sensor circuit.
2012 Nissan Rogue FSM - SR Section - SRS AIRBAG
Nissan Rogue Service Manual: Crash zone sensor removal and installation
justin_bailey
Thanks so much - I'm here now at the dealership so hopefully they find what you provided.
justin_bailey
They replaced front sensor you mentioned and another one inside and no more airbag flashing light.
Thanks.
Rogue One
2022 Honda Pilot SE
Thanks for the update! This thread will come in handy for anyone else that may run into a similar situation. If you don't mind saying, how much did it cost to get this repair done?
Return to “Rogue Forum”
