2012 QX56 Headlight Question- HELP
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
Err0xx
Car: 2012 Infiniti QX56
I just bought a set of LED driving lights to mount on the front of my QX56 and they connect into the headlights- they dim when headlights are on and they are very bright when headlights are off. I've looked at the service manual diagrams but I can not figure out where to connect the LED driving lights into the headlights. I have the headlights that have motors in them that turn with the steering wheel and they seem to be positioned where you can't access the actual headlight. The blinkers and accent light are easily accessible.
If someone could direct me as to which wire I would need to connect these new LED's to in order for them to become bright when the headlights are off and dim when they are on I would be very very grateful. I assume I could connect them to the headlight wire coming straight out of the wiring/fuse box but I'm not sure which one it is. I see the fuses labeled for headlights but none of the wiring connectors have labels. I just need to find out where the hot wire for the headlights is. I have zero capability to understand the wiring diagrams in the service manual. :(
Thanks!
Return to “Armada Forum / QX56 Forum / QX80 Forum”
