2012 QX56 - +12V Constant Source in Cabin
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
usaf-lt-g
Car: 2012 QX56 - Deluxe Touring, Technology, Entertainment, and everything else they ever made for this car.
Hi everyone,
I'm trying to find out where a good source for a constant (always on) +12V wire can be found in the cabin. Ideally somewhere behind the navigation panel. I have a bit of a project I'm working on where I need both a switched and constant power source to tap into. I've already got the switch source figured out... now it's just a matter of tapping a constant +12V source.
Anyone know where this might be?
marctronixx
you best bet is the fuse panel, or run a wire through the firewall from the battery.
usaf-lt-g
Thanks,
Pretty much what i figured, but figured I'd ask. I'll run a voltage tester and find a hot wire.
marctronixx
the cigar ports are good too.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
