butchbr73 »
https://forums.nicoclub.com/butchbr73-u266228.html
Wed Jul 13, 2016 12:03 pm
New to this board, but long time Nissan owner. This is our 4th Pathfinder over the years.. bought new in 2012, now has 83k miles. Dropped a K&N drop in filter in it at some point a few years back, only "mod" done. Right at 83k miles, CEL on and brought to dealer, p0430 b2... dealer says bad cat - $1,150+ tax for repair. I choked and picked the vehicle up. Calling Nissan warranty to see how lenient they'll be... since catalytic converters have 80k warranty. I've owned too many other Nissans to count over the years, and currently our other vehicle is an Armada.
Now the interesting part, talking with other folks (other third party shops that are much cheaper to repair cats).. cat's don't just go bad, something causes them to go bad. Now I'm thinking back and have been noticing for a few months, maybe longer but wife mostly drives it so I'm not in it much, the car had a rough idle. Noticed weeks ago from the outside that also the exhaust note was sort of popping in idle, not a smooth idle... hmm... as well, noticed a faint smell of what one might call rotten eggs but can't really place the smell, not your typical exhaust smell. Well, doing a bit of research on what would cause a cat to go bad.. engine running lean or rich could, dropping gas into the exhaust, etc. I realized the K&N filter would push more air into the engine, thereby causing the car to think it needs to add more fuel to counteract... could that be the root cause of the issues? Also one of the guys at a third party shop checked the cats with a temp gun and he said the rear ones are bad, guess you can tell by the temperatures in and out..? If the temperature in/out is too hot, its not oxidizing all the exhaust. Well, also realize a lean running engine would run hot and the exhaust would be hot, could that provide sort of a false positive for a bad cat?
Last night, I went and bought your typical Purolator air filter and put that back in and pulled the K&N out. This could all be in my mind, but I started the car and let it run for a minute and I swear the rough idle "went away" and is now much smoother idle. Driving around for a few minutes noticed a little smoother... as well, when I pulled back in and let it idle, the exhaust note is now much smoother... and that faint smell is gone.
Now, Nissan had turned off the CEL when we brought it in for a diagnosis last week.. and it has not come back on yet. I've had numerous K&N's over the years in various Nissans and never had an issue before... I'm going to run it a bit with the OEM paper filter to see how she does over time and see if the light happens to come back on. Has anyone experienced or heard of this sort of issue before between a stock filter and K&N filter?
Did I kill that cats already if by chance the engine was running lean for some time? Any Thoughts?
