2012 Nissan Versa
gravy1061
Car: 2012 Nissan Versa
Problem is with the fuel pump fuse keeps blowing even when you increase the amperage on the fuse any idea what may be causing this? :wtf2:
gsf1200s
Car: 1993 J30 (no longer with us)
2012 Nissan Versa
2003 Chevy Silverado
2003 Suzuki Bandit
1971 Honda CB750k1
I haven't had the issue with this specific part/car, but usually when fuses blow on my cars it has been a grounding issue. I would look for signs of frayed or melted wire, rust or corrosion on plugs/terminals. be careful putting in larger amp fuses as that can cause worse problems.
Eduardo922
Car: 20112 Nissan Versa S Hatchback
Haven't had this problem on mine (knock on wood).
