The_Murph wrote:
4. I haven't taken the car to the dealer yet as it is a 150 mile trip one way, so it's not too convienent. I also saw on Freshalloy, another owner had like problems and it was fixed by replacing the injectors and fuel rail. The diagnosis was a stuck injector. That could happen as the fuel system is dirtiest when the car is built and then you also have to 2 month boat ride from Japan that things can stop working properly just not being used. I know they had terrible engine and transmission calibrations on the 2011 model that was fixed with a software update. I picked up on that during a test drive of that model and refused to purchase a car that didn't run right. That software fix was incorporated in the 2012 model.
I don't know if I quite agree with your assessment here. There
may be an issue with a sticking or improperly flowing injector but if the tailpipe emissions were to exceed 20% of the federal mandate the SES would come on. There is no maybe about it, if there were raw fuel being dumped into one of the cylinders the SES would begin to flash as that poses immediate risk to the catalyst. There have been only a limited hand full of incidents that I have heard of regarding the direct inject system mostly very isolated and I cannot think of one that did not have an SES complaint with it.
Nissan has been shipping cars all over the world for decades without an issue I do not quite agree with your comments about dirty fuel system components. They are filled with different quality fuel but haven taken fuel systems apart over the years I have rarely seen any dirty or debris make it into the lines when the proper fuel quality is used. Engine and transmission calibration and unset adaptives are two different things. I have been telling people since these cars came out to seriously look into driving a car will 2000+ miles on them as a first test drive. These cars are quite quirky (as I am sure you know) when they have low mileage. Their shift timing is odd at best, although quite efficient and they get down to business when needed. However having an ecm update really helped their first year jitters.
There are many things that could cause that. It will most likely be one of those things that you are not able to pinpoint until a code is set somewhere. Personally I would not worry too much about it there is far more than enough warranty left on your car to cover anything for the foreseeable future. The dealer will most likely not be able to do anything if they cannot locate the source of a problem.
You may not be able to notice a performance change if the engine were slightly off...but your car will know.
