Need some advice on how to replace the flex disc. I've been chasing a vibration in the car for a few months and this is starting to close in on more extensive and expensive repairs. The vibration feels like it's coming from the center of the car. I'm hoping it's not the torque converter. So far I've replaced all four tires, the front wheel hub bearings, and outer tie rods with a four wheel alignment. The dealer will only sell the entire propeller shaft and the independent shop initially said they can replace just the flex disk a couple of months ago, but today said that you have to do the entire shaft, which you don't have to. So far I've found two parts that may work. Powertrain Industries 2355-115 and the Toyota part equivalent, 37511-30020. These two parts look identical and the measurements appear identical as well. Based on some eBay pictures of m37x propeller shafts for sale, these flex discs are the same thing. I'm not 100% sure that these fit the 4wd model of the M37 although, visually everything seems to match. I did do some research on the PTI website and it appears that there's will do. Tbh they are probably the original supplier...
My independent shop admitted today that it did appear cracked in places but said that it wasn't torn and should be fine. The thing is..... you don't want to wait until it tears because at that point, some serious damage will probably be done by then. Previously when initially trying to diagnose this vibration, before I replaced anything, I paid for them to look the car over and they said they didn't find anything. The rubber is pretty hard btw. My goal now is to maybe attempt this myself. I didn't know the exhaust is in the way as well as some heat shields. Having a lift would definitely make this easier, however people have removed whole transmissions with just jackstands. Prefer to be safer though. Partsouq and Amayama are the best plug but with the Tariffs... things are more expensive.. Anyone have advice, resources, or experience in doing this?
