I would put in some Fuel injection cleaner, fill the tank, get oil change. At 60K it may be just some build up on the fuel injector that hardened and that can make a hesitation on start up. Also I Agree with armybrat
A more pronounced start up feedback is normal, due to the open loop at start up. O2 sensors have to heat up before going into closed loop (where it smooth's out), plus a few other things like the thermostat properly opening once the engine warms up. It shouldn't be excessive but it is noticeable.
She sat for a while so that would make sense, Lastly check your air filter!!
