2012 M37 Power Seat Fuse
theproman23
Hi All,
I was cleaning out my car yesterday and had the seats slid all the way forward. I think I ended up draining the battery and now when I try to use the sliding switch I hear a clicking as if it's trying to draw power. I checked the battery and it was down to 8V, and after trying to charge it for an hour using another car, I got it up to 9.5 volts but that's it. So, before I replace the battery (which I think is original and proabably done) I wanted to pull the fuse out for the driver side power seat and see if may be it was draining a lot of the battery since my issue with not being able to start the car started when the seat was fully forward and I hit the memory button.
Checked all over the place and tried a whole bunch of fuses and can't seem to find the sliding switch fuse, any thoughts?
Frog
Car: 2011 Infiniti M56 S
Save yourself the headache go buy a new battery
theproman23
Hey Frog,
I actually ended up doing that and although it was a PIA to install it I'm good to go now.
Thanks!
Frog
Good to hear
