Michael, can't thank you enough. Sending you a PM now.RED_DET wrote:Save a few more dollars and when you are ready, I will give you a deal on the front SPC arms.
And you guys are missing out if you aren't considering tunerzstore.com.
How hard was the install of SPC front control arms? Any pics or tips? I'm thinking about making this my next project.beachbum718 wrote: ↑Thu Feb 04, 2016 2:21 pmIve been running the spc front control arms for almost a year.no problems.smooth as silk.and im maxed out in camber up front.
easy peazy...forgot the size of upper nut on spc but its huge.borrowed the wrench from my buddys shop. But thats the one tool i needed to borrow.i did both side at once.put front on stands,by chassis. Loosened top bolt first then side nuts.goodluck.
Nice! I'll need to get to work on this...beachbum718 wrote: ↑Sat May 05, 2018 6:19 pmeasy peazy...forgot the size of upper nut on spc but its huge.borrowed the wrench from my buddys shop. But thats the one tool i needed to borrow.i did both side at once.put front on stands,by chassis. Loosened top bolt first then side nuts.goodluck.
