2012 M37 Alarm adjustable?
prsquash
Car: 06 M35 and 2016 Q70S
My M37 alarm is so sensitive it goes off if you look sideways at it!!
I watched a you tube video where they showed a sensitivity adjustment unit in the passenger kick panel. Had mine opened and nothing like it there. Anyone had this issue and resolved it?
EdBwoy
Have a dealer check it out. From the factory, the M doesn't have motion sensors that can get triggered if too sensitive. The security system is the traditional "was a key used to gain entry?" system
There might be an aftermarket system that is too sensitive, or your car might be going nuts.
satown210
Car: 2012 Infiniti M37
2005 Nissan Xterra Off Road
There was a dealer offered shock sensor. Has a knob on it that reduces sensitivity. Should be ziptied and wrapped in foam under the driver knee bolster area.
Pimperish1
Car: 2011 Infiniti M56s
2007 Nissan Pathfinder S 4WD
2018 Nissan Rogue SV
2020 Nissan Rogue SL
I opted for the shock sensor when I bought mine, your right, it's pretty sensitive, I've asked my dealer about this numerous times and they were absolutely clueless. Even asked corporate and they referred me to the dealer. I finally just gave up. I'll have to go hunting for that adjustment.
prsquash
hmmmm. Ok, I'll check the knee bolster area. I did, however, figure a good way to bypass it. When you shut off the car the doors automatically open, but I lock them with the power button then unlock manually, open the door, manually lock it and close. No alarm noise!!! Then again when the car gets stolen I permanently won't have to worry about it going off!!
