Davealan wrote: ↑Wed Oct 18, 2017 1:33 pm
Ilya & EdBwoy,
Thanks for your comments.
Yes the vent just ar the bottom of the windshield. I believe both are set the same but I will check to make sure both driver & passenger settings are alike tomorrow morning and will report my findings.
To expand on what Ed said...if you have dual mode on, changing the settings to match might not make a difference because the car will judge what it needs to do to match them accordingly. You might have the window open on one side so the car will not blow there, etc.
Push the 'Climate' button and then make sure 'Dual Mode' is turned OFF. Before doing this, set your driver side to 90 and passenger side to 60. You should IMMEDIATELY see the passenger side go to 90 after turning off Dual Mode.
