2012 G37XS sedan rear brake kits
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
F22Maybach
Car: 2012 Infiniti G37XS
Need some inputs on which brake kit people have had success with for 2012 G37Xs
Need to replace rear rotors (12.1” or 307mm) and pads. I narrowed down my options to below but open to diff ideas. I don’t want to go w big brakes.
Goal is to get quality not cheap crap.
I found below options on autoanything.com
1. Stop Tech select Sport Brake kit ($105)
2. EBC ULTIMAX rotor kit w yellow stuff aggressive pads ($240)
3. EBC Premium rotor kit w ULTIMAX daily driver pads ($94)
4. Power stop Z23 Evolution brake kit without calipers ($160)
5. Centric Premium rotors ($89) + Hawk HPS pads ($76)
Thanks for the help, team!
$tarter
Car: 2011 G37S sedan 6sp
That's not enough info to give good advice. What are you looking to achieve? How do you use the car - daily driver, track days, etc.? The Xs unfortunately didn't have the bigger rotors and wheels of just the S, so I understand your wish to improve.
F22Maybach
Looking to get quality brakes that will give me piece of mind on safety. I’m an aggressive daily driver. I wfh so really don’t drive much other than local & weekends.
I went with #5. Thoughts?
Also do I need to get my brake line bleed while getting this work done?
$tarter
Not a bad choice. And don't worry about bleeding the brakes unless you've got a spongy pedal.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
