2012 Armada passenger door will not open from inside or out
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
HinestonRebel
Car: 2012 Nissan Armada
my wife has a 2012 nissan Armada that we bought used. About a month ago we got in just fine and when we got home the passenger side door will not open from either side. I was able to get the door panel off after pulling the front passenger seat out and the glove box. the lock cable seems to be activating properly but the inside door cable has a lot of slack. the outside handle cable seems to be operating properly. Does anyone know how to get the door open besides destroying the door actuator to release it from the door striker.
PalmerWMD
Car: 2004 350Z
Is it very cold where you are?
I once had a recurring problem with my Xterras rear door in cold weather only.
Turns out some ice was forming.
So I sprayed the heck out of the insides with WD40 ( no no water will condense)
Problem never came back..
Not saying yours is the same cause.. just a though...
PS: Welcome to Nico!
HinestonRebel
we live in Louisiana so it doesn't get very cold here. I ended up smashing the outer housing of the actuator to be able to get to the release lever for the door striker.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
