2012 Armada electrical issues
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
ClaudiaS
Car: 2012 Nissan Armada SV
Hi,
I have 150,000 miles on it. Only owned for last 10,000. It's in the dealer now, getting 3rd brake light replaced as it was out. Was towed for no start and relay was replaced. Prior to all this, had a few odd things, wondering if related.
1-while driving once the E brake warning came on. Hadn't bumped it or anything. After pulling over and pushing for the release the light went off.
2- middle of night while I glanced out window, brake lights were on. No key, no one near it for a whole day. Couldn't get the lights to shut off until I started it and put into drive and then park. Never occurred again. At that time, 3rd light was not on. Didn't realize it was out as in not working.
3-connector for tow lights not working
4-front 2 driver charging ports do not work.
Thoughts??
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
ClaudiaS wrote:
Wed Sep 08, 2021 11:03 am
The e-brake uses a "grounding switch" built into the ratchet mechanism, and they usually engage in the first one or two ratchet teeth. If it was on the first tooth instead of fully released, a feather might make it light up. If it doesn't happen again, I wouldn't worry about it.
Nissan brake pedal switches on just about every model are notorious for both sticking and failing. I wouldn't trust it. Aftermarket replacements are cheap, and it's an easy job. No tools needed, twist-out, twist-in.
There are relays (I think 3) that need to be added to the underhood fuse-and-relay box for the tow lights to work. There are also 3 dedicated trailer fuses in the IPDM (right behind the F&R box). If the lights never worked, someone probably installed the 7-pin harness but never added the relays. Relay part number is 25230-79917. If they worked before but don't now, check the fuses.
The left and right front sockets are on different fuses, but the righthand one shares its fuse with the console socket. So if the console socket is also out, you probably have 2 blown fuses. For reasons I never understood, Nissan sockets have thermal fuses built into them in addition to the fuses in the fusebox, and the thermals do fail. So 2 bad sockets or a combination of bad sockets and blown fuses isn't out of the question.
ClaudiaS
Wow amazing thank you.
VStar650CL
Technical Expert
You're most welcome. Happy motoring!
macgiver
Happened to me 93 J30 , AND to buddies Honda Accord that there is a little plastic or rubber 'insert' on the brake pedal arm - higher up under dash - it breaks/falls apart and will be #1 reason for STUCK-ON brake Lts , epecially older cars , cars seeing high amb. temps . When replaced, you may not need the brk sw. itself to be adjusted ! The cars have'em , gotta look , look for the little hole where they're re sposed to reside FIRST before you attack the brk sw. , which of course could be the culpret. Little inserts usually $ 6-12 at dealer!!!
They basically give a "softer" contacting to brk Lt sw than the STEEL pedal arm , ya know , is it's purpose.
VStar650CL
Technical Expert
macgiver wrote:
Wed Sep 08, 2021 1:36 pm
That was only a problem on earlier stuff with metal-actuator switches, the rubber bumper was there to prevent noise. The later models all have plastic actuators and don't use a bumper, just a plain metal stop. Trust me on this one, the switch is sticking.
ClaudiaS
Wellllll... picked up truck Thurs. Today drove to the store, came out...no start just click click. Sundays...nothing open. Got a tow finally and a friend came to our rescue to get us 26 miles to home. Gurrr
macgiver
" just click click " ? ........... 44 mag pointed at it and CLICK - B O O M :rotflmao
ClaudiaS
Turns out it was the starter. Been fine ever since.
VStar650CL
Technical Expert
ClaudiaS wrote:
Thu Oct 07, 2021 5:01 pm
Glad to hear you resolved the no-start, but that won't explain the brake lights. I'd keep an eye on them if you haven't changed the switch. The brake lamps won't deplete your battery as fast as headlights, but they can still easily kill it overnight.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
