I wouldn't say more than that. Upgrade the unit!!!TonyN wrote:better speakers and headunit
Depends on how long and how loud you listen to music. I find the factory stereo goes 'flat' above 20... you loose a lot of high frequency response and in general sounds like crap.rayjgold wrote:wow, you think it is not loud enough? I am not able to put the volume half way before feeling that it is too loud.
My rogue came with the Bose stereo and subwoofer....do you think I would have the same problems you mentioned? also, do you know where the subwoofer is located?philipa_240sx wrote:Depends on how long and how loud you listen to music. I find the factory stereo goes 'flat' above 20... you loose a lot of high frequency response and in general sounds like crap.rayjgold wrote:wow, you think it is not loud enough? I am not able to put the volume half way before feeling that it is too loud.
There isn't much you can do with the stock system. If you want more volume, you need more power. The simplest way to do that is add an outboard amp with new speakers and perhaps a sub. This way you can keep the factory headunit with touch screen, nav, etc.
I would look for a reputable stereo installer to select components and install it for you. Unless you are handy at doing this yourself.
The subwoofer is located inside the spare tire. Simply lift up the luggage floor and remove the cargo organizer (if you have one).rayjgold wrote:My rogue came with the Bose stereo and subwoofer....do you think I would have the same problems you mentioned? also, do you know where the subwoofer is located?
This "problem" is completely dependant on your personal preference and is highly subjective, if you're happy with your stereo then you have no problem!!My rogue came with the Bose stereo and subwoofer....do you think I would have the same problems you mentioned? also, do you know where the subwoofer is located?
