RickLDZ »
https://forums.nicoclub.com/rickldz-u310668.html
Thu Aug 24, 2023 10:11 am
Purchased a Versa for my grandson and the seller said the passenger side speaker doesn't work and also when you go higher than half volume the sound is all distorted. Other than that is was a well maintained car and knew my grandson would want me to swap out the radio to something a little more modern and since I figured it was either bad speaker(s) or radio no big deal. Got the car home and definitely an issue so I removed all 4 door panels and unhooked the passenger side front, no difference, then unhooked the driver side no difference. Moved to the left rear passenger side and as soon as I unplugged it the passenger rear on the right side played great! So I plugged in the driver side and it went back to distortion. Unplugged it and went to the passenger side front and there was still no sound but the rear speaker continued to play great. I then started switching the speakers and verified they all worked and worked well. Guess it must be the radio. New unit came in, along with the wiring harness and antenna adapter and 30 minutes later it was all installed. Turned it on and and I had the exact same problem! OMG. Figuring that something in the main wiring harness was probably messed up I'm now at lost as to what I can do. I checked the speaker wire connectors and all tested fine, I even purchased 2 new speakers, cut all 4 connectors and wired a new speaker to the rear passenger side that worked and it played fine. Hooked the new speaker to the other rear passenger and suddenly it went back to the static and distortion. I have made sure the polarities are correct as per another post I saw on this forum. Anyone have any ideas other than running all new speaker wires?
