offthewall »
https://forums.nicoclub.com/offthewall-u293544.html
Mon Dec 09, 2019 6:54 am
Hmmm, is it misfiring? Are there any engine codes? I've experienced this on a Versa 2012 1.6L CVT. It was around 100k miles, the issue was the ignition coils were going out. Engine was misfiring though and showed code for misfiring, and we replaced all 4 ignition coils and seems to be running great now. The spark plugs were changed prior to the misfires. Even though it says 105k, 85k is getting close. If those spark plugs weren't replaced yet, depending on how you drive the vehicle and many other factors, the plugs will deteriorate at different rate, should check it and see if they're going bad.
