SER Wes... did you drop your se-r?SER Wes wrote:1.Pro kit is what is probably the most common springs put on these cars. Its a nice drop without be too much imo. Regardless you will have to get an alignment after you change them out. Just let the car sit over night and drive a little bit before you do so the springs will settle a little bit.
2. I have seen 2 with custom leather seats. It was an online company that did both and they looked awesome. Costed something like 1.5-2.5 grand though.
3.My favorite name brand exhaust for the b16 is the greddy SE. I have never heard the ti-c in person, but i have the SE and it sounds great. Know that both are only an axle-backs(basically only muffler) though, so you will not see much of any hp gains if you are looking for them.
4. I'm sure you could get it to work, but i have no help unfortunately.
You may also want to look into an intake. If you do then your options are k&n(short ram) or injet(cold air), unless you want to try and make your own. Both are great quality. I have k&n and love it.
No i have not actually. Looked into it but never pulled the trigger.MikeisSUPERBAD wrote:SER Wes... did you drop your se-r?SER Wes wrote:1.Pro kit is what is probably the most common springs put on these cars. Its a nice drop without be too much imo. Regardless you will have to get an alignment after you change them out. Just let the car sit over night and drive a little bit before you do so the springs will settle a little bit.
MikeisSUPERBAD wrote:I installed them a while back but forgot to post.
3k yellow for the fogs and 5k for the hi/lo beams... Have no complaints what so ever and they work perfectly. No flickering at all and they are super bright.
I've had them on 3 cars so far my last car was an aprons coupe and they worked perfectly for 3 years
I recommend them!!
