2011 Sentra rattles over bumps.
Texas Jay
Car: 2011, 2013, and 2015 Nissan Sentras. First Nissan: 1978 Datsun 510 Hatchback.
I have three Sentras. This is my oldest. It has 104K miles and it generally looks and runs like new. But when I go over bumps, it rattles in either the engine compartment or underneath. It’s been this way for a few years and it’s not getting any better or worse. I’ve heard it could be the subframe(?). Does that make sense? The dealer says it will be about $1,700 to replace the subframe, if that’s the problem.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Is it rattling mostly over 2-wheel bumps (like speed bumps) or 1-wheel bumps (like potholes) and turns? If it's the former then it may be subframe bushings, a lower torque mount, or just something loose in the undercarriage. If it's the latter then it's most likely sway bar bushings, links, or a bad (shifted) bar. Do you have any signs of uneven tire wear? If so it may be a control arm or ball joint.
Texas Jay
VStar650CL wrote:
Fri Apr 30, 2021 7:00 pm
The shocks, struts, and lower control arms were replaced at 92K miles. Turning doesn’t cause the noise. Going over any bump (large or small) will cause the noise. It’s like a tinny jingling. It’s not the heat shield or the transmission mounts (just replaced).
VStar650CL
Technical Expert
If it's tinny and it isn't a heat shield, rap on the catalyst with a deadblow hammer and make sure it isn't cracking internally. Also, if the flex-pipe shields are tack-welded, pry on them and make sure there aren't broken welds. It's very common for those to look fine even though they're busted.
Texas Jay
VStar650CL wrote:
Fri Apr 30, 2021 8:29 pm
Thank you!
jethbon
Car: 2014 Nissan Pathfinder
Maybe the exhaust is hitting something.
bobbyidrake
Car: 2010 Nissan Sentra SE-R Spec V
I don't get a rattle on my subframe it's more a squeak. When I had the rattle i believe it was my strut mounts. Which I replaced a month ago and no more rattle.
