doomcomplex »
https://forums.nicoclub.com/doomcomplex-u306514.html
Sat Jun 25, 2022 6:23 pm
Hello, I've been working on this issue for about a month now and I'm really not sure where to go from here, maybe someone can point me in the right direction?
Issue: For the last month or so, car occasionally won't start when I turn the key. I get one 'click' sound and then nothing. There is no engine cranking sound and no 'click click click click'. I initially thought this was a problem with the neutral safety switch, as sometimes the car would start if I put it into neutral. However, yesterday my car failed to start and would not start no matter what I did, even in neutral. The car eventually did start (after about 20 attempts), after I jiggled the keys. I don't know if that was a coincidence or not. Since then, the car has started normally.
Diagnosis so far: I have cleaned the battery terminals and tested the battery, starter, and alternator. All appear to be working normally.
What next? The way I see it, there are 4 possible causes. 1) The ignition switch, 2) the start relay, 3) the neutral safety switch, or 4) some loose connection anywhere in the ignition system.
Does anyone have recommendations on how I should proceed in diagnosing this issue? Similar experiences or insight?
Thanks in advance.
