Thanks, VStar, for confirming the freezer test;
two of the mechanics that were working on the car had not thought of this before. The Nissan dealership service shop gave me the Nissan part number I need for my Rogue (237101VK0B) and told me they can reprogram a 2nd hand ECM with this part number--even if its VIN is still associated with another vehicle. So, I have found one for a little over $100 on eBay that has this exact part number on a sticker on the actual part. I am not sure what you mean by the
Hitachi part number. Is that different from the Nissan part number above? Or, am I correct to assume that, if they both have this exact
Nissan part number, they are compatible?
One last question remains regarding this whole matter: the eBay seller uploaded pictures of the car from which they they pulled this ECM. Another picture shows the VIN on the sticker on the actual part. I put this VIN in the system on a website (below) that sells OEM Nissan parts. The description that comes up is exactly the same in every respect as the one that comes up when I enter the VIN on my car. It indicates that the same part works for both vehicles. But, the
seller lists in the
description of the ECM he is selling that it was pulled from a 2.5L, 4-cyl. 2011 Nissan Rogue
with FWD (assumed to be "front-wheel drive"), even though the description associated with the VIN (on the website below) says his car is a
"rear-wheel drive" vehicle; mine is rear-wheel drive. If everything else is compatible between the ECMs, would this slight difference in the drive train (FWD vs. RWD) make the ECM he is selling incompatible with my car? I could not find this answer anywhere else online. If this 2nd hand ECM does not end up working when the Nissan mechanic installs it, I will
still have to pay almost $300 for labor and programming costs there and do so the second time around when I purchase the more expensive new part from them.
I am trying to make sure I get this purchase right from the beginning.
Thanks for your timely assistance. I am hoping to buy the part and get it shipped as soon as possible, so that I will not incur any charges for the Nissan dealership to hold my vehicle while I await this 2nd-hand part.
https://www.nissanpartsdeal.com/page_pr ... rol_module
