2011 Rogue TSB's
nightfawl
Car: 2011 Nissan Rogue SL AWD
Is there somewhere that I can read all of the recalls and TSB's for the 2011 Rogue? I just purchased the car and it still has 1 year left on it's bumper-to-bumper warranty and I want to make sure I catch anything that might go wrong while it's still under its full warranty period.
The only site I found was this one, but you need to purchase a subscription to read the TSB's, which seems a little stupid to me.
http://www.nissan-techinfo.com/TSB/TSB_ ... sbType=TSB
Rogue One
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
nightfawl wrote:Is there somewhere that I can read all of the recalls and TSB's for the 2011 Rogue? I just purchased the car and it still has 1 year left on it's bumper-to-bumper warranty and I want to make sure I catch anything that might go wrong while it's still under its full warranty period.
Try this site. http://www.automd.com/tsb/nissan_m/rogue_mm/
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
You only need a subscription to see the entire document, but from this web site you can see the general overview description and get a good idea of the issue, what components it affects, how serious it is (recall, maintenance, reprogram etc.), and the TSB reference number which is important when dealing with the dealership.
The best source for this information is your dealership. Their system gets the updated bulletins and recalls efficiently, and the computer will automatically tag your vehicle VIN with applicable bulletins. Just ask your dealership to check for you, and if you want to independatly verify use your link above to generate the truncated list.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
read my signature link: All Nissan TSB's
nightfawl
Do you guys get Nissan to do all the TSB's on your car regardless or only if you see a related issue?
Rogue One
2022 Honda Pilot SE
nightfawl wrote:Do you guys get Nissan to do all the TSB's on your car regardless or only if you see a related issue?
Only if it's important. I'm willing to bet any TSB issues have already been taken of. I wouldn't think twice about it.
ImStricken06
2016 Kia Sorento
they only fix the mandatory ones(even if the problem isnt visible). the others are fixed as they become a problem.
followingnfront
Car: 2017 Maxima S
They need one for a clicking drivers seat. Just developed on mine (and no its not a flashlight this time lol). Ive heard about this problem with Maximas but I disnt know the Rogues had it too
Rogue One
2022 Honda Pilot SE
followingnfront wrote:They need one for a clicking drivers seat. Just developed on mine (and no its not a flashlight this time lol). Ive heard about this problem with Maximas but I disnt know the Rogues had it too
Hmm, hard to say. Is it an actual clicking sound or more akin to a tapping sound. Do you have a rough idea where it's emanating from? How often does the noise happen and under what circumstances?
followingnfront
Car: 2017 Maxima S
It seems like its coming from the back part of the seat. I believe it is making the sound because the seat is ever so slightly "rocking" under moderate/hard accel, and moderate/hard braking... Basically any movement that would make me move backward or forward in the seat considerably, will make a "click" noise. It also happens sometimes when I simply get into the seat from outside the car... And I'm only 200lbs.
Rogue One
2022 Honda Pilot SE
followingnfront wrote: It seems like its coming from the back part of the seat. I believe it is making the sound because the seat is ever so slightly "rocking" under moderate/hard accel, and moderate/hard braking... Basically any movement that would make me move backward or forward in the seat considerably, will make a "click" noise. It also happens sometimes when I simply get into the seat from outside the car... And I'm only 200lbs.
If I were to hazard a guess... Best case scenario, one of the seat tracks needs to have it's bolts tightened to the floorboards. Worse case, one of the seat tracks is cracked and needs replacing. If it's the latter, I should think it would be covered under warranty.
ImStricken06
2016 Kia Sorento
post6420532.html?hilit=drivers%20seat#p6420532
Qashqai
nightfawl wrote:Is there somewhere that I can read all of the recalls and TSB's for the 2011 Rogue? [...] I want to make sure I catch anything that might go wrong while it's still under its full warranty period.
I have a 2011 Rogue AWD as well and the most important TSB is about the fuel sender units (the AWD version of Rogue has two sender units, due to the shape of the gas tank - differential caused a bump). For some reason the fuel sender units are not "sending" the correct amount of gas and it may cause an expensive repair in the future. If you take your car and ask them to replace the sender units, they may not change them. However, if you have the following complaints, they will change them:
- After filling the gas tank, the fuel level shows FULL for 150- 200 km, then it suddenly starts to drop
- Sometimes, although the tank is full, it doesn't show "full". After driving for 100-150 km, it suddenly becomes "full".
I had these complaints and they changed the sender units.
ImStricken06
2016 Kia Sorento
and the steering screw/nut that could come loose
nightfawl
When I am coming to a stop I hear a very strange creeking sound coming from the dash. It almost sounds like scratching or something. Very hard to describe. But I only hear it when the car is almost at a complete stop when I am braking. Does this sound familiar to anyone?
Return to “Rogue Forum”
