2011 Rogue True Roof Rack Load Limit
BigMax
Car: 2011 Nissan Rogue
I have a Rogue SV with the factory rails installed and am looking to get crossbars to mount roof rack systems (kayaks, bikes, etc). The owners manual says the load limit is 99 lbs and shows it with the OEM crossbars. Any idea if the low load limit is due to the roof to rail, rail to crossbar, or crossbar strength (weakness)? The fit guide for Yakima and Thule crossbars give a load limit of 168 lbs and their crossbars appear much stronger than the OEM crossbars, suggesting it may be the crossbar strength that is the problem.
I am looking at an estimated 150-160 lbs loading and will spring for the extra cost if the weakness is the OEM crossbars and the Yakima rack will get me to 160. I might even go so far as to replace the factory rails, if it will get me there. But if the weakness is the roof-rail attachments, I guess I'm stuck.
Any advise would be appreciated.
BigMax
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
BigMax wrote:I have a Rogue SV with the factory rails installed and am looking to get crossbars to mount roof rack systems (kayaks, bikes, etc). The owners manual says the load limit is 99 lbs and shows it with the OEM crossbars. Any idea if the low load limit is due to the roof to rail, rail to crossbar, or crossbar strength (weakness)? The fit guide for Yakima and Thule crossbars give a load limit of 168 lbs and their crossbars appear much stronger than the OEM crossbars, suggesting it may be the crossbar strength that is the problem.
BigMax
i think its the weight of the object, catching wind- once the car is moving. i dont think the OEM long rails are bolts down on the roof strongly enough to support such weight if you slam on the brakes, or are doing 65mph.
aftermarket rails are attached to the edges of the roof a little more securely, in my opinion.
Return to “Rogue Forum”
