unistang »
https://forums.nicoclub.com/unistang-u170768.html
Sun Nov 29, 2015 7:30 pm
All,
Just did the transfer case drain and refill last night and I have a leak somewhere that I can't pinpoint. This is my second time doing this on this car. The first time I had no issues, even reused the plug gaskets. This time not so much. The first time I tried reusing the gaskets again and I saw a leak so I headed to Nissan, bought two new crush washers, removed the old and in with the new. Everytime I drive the car I can smell oil had dropped on the exhaust when I pull into the garage. I'm out of ideas. Torqued down to 35lbs on both bolts (drain and fill). Thoughts before I take this in? Is there a vent maybe that is purging a possible overfill?
I changed the trans fluid too (drained and added 5qts of NS-2). Not sure if that matters.
