2011 Rogue The Evil Cruise Control set light flashing
vidshader
Car: 2011 Rogue S
Hi All! first time poster. I'm now a victim of the EVIL Cruise control set light flashing on my rogue. After the car sits overnight all is good with the cruise for the first couple of miles then the dreaded flash occurs. I've replaced both brake pedal switches plus installed a new battery. I bought a OBDII/CAN code reader only to find no codes in the module.
The coolant temp is normal. I've checked the fuses and all is good. I had the car serviced about a year ago by a local Nissan import service. CVT fluid changed,Coolant flushed,New plugs.
This curse just started about a week ago. When I could set the cruise it would disengage about every 5 miles.
Now all the cruise will do is flash and sometimes I can't get it to turn on at all. Any help appreciated!!
datechboss101
Car: 2016 Nissan Rogue SL -- RIP
2018 Nissan Kicks SR -- RIP
2019 Nissan Rogue SV w/ Prem. Pack
Did you check the cruise control module? That could be the issue.
vidshader
Car: 2011 Rogue S
Please explain more... Where is the module located ? I've downloaded the Nissan Factory Service manual and don't see a cruise control module.....Thank you for your reply. regards
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Thanks for the heads up. I didn’t know this existed.
My rogue is 2 yrs older, so I’m planning to only use cruise control only when I really need it now.
I have a habit to use in the city or neighborhoods where I want to maintain low speed. 25mph or so.
Never really thought of it failing.
Reason I never open my sunroof as much when I hear people having problems with that too in the past.
Basically, I try not to overuse something that could break.
datechboss101
vidshader wrote:
Sun May 05, 2019 8:31 pm
https://www.ebay.com/b/Cruise-Control-U ... n_51051313
I hadn't dealt with this issue before, but a buddy of mine removed his cruise control system on his 6th Gen Accord. But in this eBay listing, it shows what the module should look like. Also, I forgot to mention, is to check the fuse for the cruise control.
vidshader
Car: 2011 Rogue S
Thank you
Return to “Rogue Forum”
