Qashqai wrote:I guess all the "invisible" parts, like the engine compartment, underneath the hood etc, don't need to have the pearl effect. My Rogue is Dark Gray and under the hood it looks like it even has no clear coat. It looks matte.
jps045 wrote:I understand but when you open the doors & the trunk lid you can plainly see it is a different color.. The frame when you open both front & back doors at the same time you can see the difference
I'm not sure I thoroughly understand where the color difference occurs on your vehicle. For the most part, when I think "frame"... I think of the underside of the vehicle and some areas inside the engine compartment. Are you saying the color difference occurs when you compare areas of the engine compartment to the body (exterior) of the vehicle... or is the difference when you compare all the inside door openings ("including" the trunk lid are) to the body (exterior)?
I have a 2009 in Pearl white. After reading this thread, I thoroughly examined my Rogue. The insides of all doors openings including the inside of the trunk lid and trunk lid opening are all painted pearl white "with clear topcoat", and all are a perfect match the exterior body color and finish. The engine compartment however is just a plain white. No pearl finish... no clear coat. I never noticed it before but its not a big deal to me. The reason the paint appears to be a different color between the frame area of the engine compartment and the exterior is only because its missing the pearlescent topcoat which imparts different color hues due to the blue / green metalflake properties of the top coat. On your specific vehicle, if the interior of the door openings is lacking the pearl finish and topcoat I'd be alarmed. "If" you are only talking about the engine compartment I'd be shocked, if after inspection by a Nissan rep, they offer any form of restitution.
