2011 Rogue - Daytime running lights stopped working
zer026T
Car: 2011 Nissan Rogue SV FWD
Hi folks, I'm in Canada where DRLs are a requirement to pass provincial safety inspection every two years. Over the winter they stopped coming on automatically when the car is started. No fuse from what I can tell. Any ideas? Tried searching but came up empty handed. Thanks in advance.
sprocket
There is a fuse and a relay, refer to the Daytime Running Light Section in the FSM. Give it a read, should help you find the fuse, that's where I'd start!
http://www.nicoclub.com/FSM/Rogue/2011/EXL.pdf
zer026T
Thought I'd close the loop on this.... Turns out it was a bad high beam bulb. Apparently the DRLs will not work if the high bulb is burnt out. A quick 5min fix - nice when something is easy for a change :)
otto888man
Thanks for the update.
Return to “Rogue Forum”
