kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Tue Aug 02, 2011 12:50 pm
I see where you're coming from on this one, try to beat them at their own game, but I don't think it will get you anywhere. There are no specs on "vibration", as there really isn't a way of measuring it.
If you read technical service bulletins for various vibration-type issues it's all very subjective, basically the tech takes the vehicle for a drive and "if you notice a vibration go to step 2 etc...". Or, in this case, "if you notice vibration between 5 and 15 mph under light acceleration, this is normal and within design spec, no action is necessary or possible". There is no quantitative spec for the vibration, just the observations of the tech, and Nissan has this within the tolerable/allowable limits of this vehicle, and it isn't a maintenance or drivability concern so that's the end of story. Even if they wanted to fix it there isn't anything they can do, that's how the engineers designed the car to operate. You can't insist that the dealer "repair" something that is a preference.
I personally would like them to fix the engine noisiness and CVT low-gearing and sluggishness in extreme cold weather, but it's not possible, that's the way the car is designed and I have to live with it. Simply put, there is no fix, that's how it was designed and from a technical stand point there is no problem, only my preference that the vehicle should have been designed differently. Your dealer service shop can't address design parameters unfortunately.
