2011 Rogue - rear door won't lock / unlock with power locks
ErikTande
The power door locks on the rear drivers door stopped working on my 2011 Rogue. I can lock and unlock it by hand, but the power controls don't do anything. Is this a bad actuator? What's the part number I need to replace?
Thanks!
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
Check the wiring and switch mechanism itself before replacing the actuator. The wiring where it comes through the door post to the door after repeated openings and closings can break. Switches just finally go bad. Check these areas with a multimeter if they prove working and intact then the actuator is the next logical choice.
I just went and checked my 2011 fsm. There were about 4 of the sections that I did not copy and the glass /window was one of them so I can’t help you with a part number.
You might try rockauto or someplace like that they sometimes have part numbers in their descriptions.
Return to “Rogue Forum”
