Did Search, no help.
I did pass side plugs without major hassle.
Driver side.
Rear plug is completely covered by thick harness run.
How do I get to the plug?
I do not believe, coil will come out without harness moved quite a bit, so how do I move harness? There's zip tie that holds it to some sort of bracket right across the coil, and then master cylinder blocks any view at where it's connected to the engine block. Cut zip tie and then re tie after done?
The other 3 plugs I see no issues, just managing some tubes and that harness to a different position.
I need to r/p it tomorrow am.
Thank you for insight.
