2011 QX56 Cabin Filter Change
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
TXmudman
Car: 2011 QX56
Anyone tried this yet? Looks easy enough in the shop manual, but the dealership is sure that I will break some expensive clips off of the dash assembly in the process of doing it. If you have any experience with this, I'd like to hear about it. Thanks.
TXmudman
Car: 2011 QX56
Update: I finished the job, and it was easy. After removing the six screws that hold in the glove box, some six or so plastic clips have to be pulled out as you pull back on the glove box to remove it. Unhook the battery, because you have to unplug the air bag sensor in the process.
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
2010 and older QX56 and any year Armada you just have to remove the glove box, there is no sensor removal. Just a heads up for everyone!
Return to “Armada Forum / QX56 Forum / QX80 Forum”
