Freon "somehow" escaped after your re-assembly , enough gone to come out Warm/Hot @ vents, yet still enough "residual" to enable compressor . (Lo-press. Sw. not activated). Because when full , the Higher system pressure comes out relatively fast , then leakage wanes when getting Lo. Is what it is ? Your leaking,has settled and system is at that "magic # pressure" ? O-rings , comp. seals can "relax" at that "magic pressure" and almost COMPLETELY STOP LEAKING of any real significance !!
