bryanclar »
https://forums.nicoclub.com/bryanclar-u254465.html
Tue Jul 28, 2015 2:31 pm
Hi all. I'm a newbie here but familiar with other car forums. Our 2011 Quest LE's (original owner, 48k miles, well maintained) driver's side HID headlight just went out. The rest of the bulb cluster works fine, including the high beams. We noticed it because I saw condensation in the assembly and wanted to turn on the lights to heat things up. When it didn't come on I bought a new bulb (not cheap, btw) and the new bulb didn't work...which is why I'm here. Before I start taking everything apart looking for a bad connection, is there a usual suspect I should try first? I did a search on the forum and didn't see anything.
I'm wondering if the condensation has something to do with it. Assuming that's the case...do you think fixing a possible leak in the assembly will fix the problem? is there a failsafe that if things get moist the HID cuts out?
Thanks in advance!
